ProScan
Software Provider
Ontario, Calif.
Bob
ProScan
Software Provider
Ontario, Calif.
Any program that edits favorite list has to work. It is still using the exact same format 1.0 for favorite lists as for all BCDx36/SDS models. What differs are that global filter will be greyed out in profiles and will not be available in favorite lists when Sentinel are set to SDS150. If you switch target back to SDS100 then filter settings will be intact and preserved in the favorite lists even if you edit and save using SDS150 as target.
/Ubbe
One other change on the SDS150 is the Control Channel Type at the site level on P25 Trunk & P25 X2-TDMA systems.
{edit} I believe that's the only other change.
ProScan
Software Provider
Ontario, Calif.
To anyone that has the SDS150 and using ProScan
I need a test performed to get the bluetooth symbol hex code/s in the protocol.
Post here the code/s so others don't test.
With ProScan communicating with the SDS150, go to the Test & Extra tab and see what the 1st few ASC hex codes are. It will be before the date. It may be just one hex code.
Bluetooth symbol looks like this
@jasonhouk @N9JIG
ProScan
Software Provider
Ontario, Calif.
I forgot to mention. Set the scanner type to SDS100.
Enforcer52
Voice Of The Piney Woods
Lake Livingston, TX
From an end of January release date to Dec. 11th!
Bob's dedication to the Uniden scanner owners is unparalleled.
We should all be thankful we have someone so helpful to everyone (not just Uniden folks) here on RR.
Thank you very much Bob, we are all very appreciative of your dedication.
Ubbe
Stockholm, Sweden
As long as it is a site in a system it will add FDMA to the parameters for that site, even if it is SmartNet or DMR or NXDN and independent of what target model you choose in Sentinel 3.0
/Ubbe
ProScan
Software Provider
Ontario, Calif.
/Ubbe
Correct. It will show in the files, for all trunking types, just not used.
ProScan
Software Provider
Ontario, Calif.
Here's the 1st test version supporting the SDS150.
SDS150 fully supported except Bluetooth. That will be looked at later.
It's not packaged up into a setup file. Unzip and copy the files over the originals. Stop ProScan 1st.
I forgot this:
24.4.0.1
  • Added - SDS150 support except Bluetooth.
  • Added - SDS100 Headphone L/R Output option.
  • Added - Source Client & Web Server - Peak Listeners now shows time of occurrence.
dave3825
Suffolk County NY
24.4.0.1
While Bob was busy updating Proscan to support the SDS150, he also made a slight change to the RRDB Differences feature. Now, it will tell you if there is a change in programming without the need to scroll down on large systems or look at the RRDB Change history.
Definitely the most popular and feature rich scanner software in the world! Thanks Bob!
ProScan
Software Provider
Ontario, Calif.
Very nice demo. Thank you.
ProScan
Software Provider
Ontario, Calif.
I received my SDS150 today. A few display issues:
X bluetooth symbol move 1 position right
GPS reversed colors not showing B4, BE, BF
satellite signals missing rectangles
?check location deg, minute, second symbols are ok
K4EET
Chaplain
Severn, Maryland, USA
Happy Birthday Bob! May your day be filled with good wishes from family, friends, and all who love your ProScan software. Take the day off! You deserve it (and lots more) for all that you have done for us and for making ProScan the best scanner software on the planet. Blessings, my friend. Dave K4EET
