Tom - absolutely. You can mix and match as many signal role and voice role receivers as you like - provided you have the ports, memory, and CPU to support them.
10-75
New York
Thanks 10-75. What is the device name as displayed in the Unitrunker receiver window?
jdd1957 - what version of Windows is this?
Rick, It displays AirSpy.... FYI, I am running Windows 7..... Bill
Sorry 10-75. I'm asking for the name displayed in the receiver window. That's the Receivers tab on the main program window.
Open the AirSpy receiver window. What does it say in the "AirSpy Device" field?
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
OK. got it working.
Thanks. . .
10-75
New York
Rick, It was blank..... I clicked on the window and a drop down appeared and I was able to select AirSpy and it works now! Thanks!
10-75
New York
Rick, Spoke too soon..... It did work.... Once.... I stopped it now I can't restart it.....Bummer...
10-75
New York
Rick, If I unplug my AirSpy, plug it back in and then hit play I can get it to run briefly....Then it shuts down.... Thanks again for your help....
Weird.
Okay, 10-75 ...
On the receiver window Info tab, check "Logging".
Unplug the AirSpy, plug it back in and click Start.
After it stops, click Start again (which should fail).
Click on the receiver window Folder tool button.
Look for a log file named "Tuner-20150613.log" or similar. You can open it in Notepad.
Please post the contents of that log file here.
10-75
New York
Rick, Here ya go.... Bill
Log file originally created as .\R00000002\Tuner-20150614.LOG Version: Unitrunker 1.0.31.18
Opening.
Setting Policies.
Gathering interfaces.
Found 0 associated interfaces.
C0 0A 0000 0000 003F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 /
C0 0C 0000 0001 0001 00 /
40 15 0000 002D 0000
C0 10 0000 000A 0001 00 /
C0 0F 0000 0007 0001 00 /
C0 12 0000 0000 0001 00 /
C0 0E 0000 000A 0001 00 /
C0 11 0000 0000 0001 00 /
40 0D 0000 0000 0004 01 00 00 00
40 01 0001 0000 0000
Closing.
Opening.
Setting Policies.
Closing.
Opening.
Setting Policies.
C0 0C 0000 0001 0001 00 / 01
C0 10 0000 000A 0001 00 / 00
Closing.
Opening.
Setting Policies.
Closing.
Opening.
Setting Policies.
Closing.
Opening.
Setting Policies.
Closing.
Opening.
Setting Policies.
Closing.
Opening.
Setting Policies.
Closing.
Opening.
Setting Policies.
Closing.
Opening.
Setting Policies.
Closing.
Opening.
Setting Policies.
Closing.
Opening.
Setting Policies.
Closing.
Opening.
Setting Policies.
Closing.
Opening.
Setting Policies.
Closing.
Opening.
Setting Policies.
Closing.
Opening.
Setting Policies.
Closing.
Opening.
Setting Policies.
Closing.
Opening.
Setting Policies.
Closing.
Opening.
Setting Policies.
Closing.
Awesome! Thanks Bill.
Code:
C0 0A 0000 0000 003F 00 | Get Version String
C0 0C 0000 0001 0001 00 | Set Sample Rate
40 15 0000 002D 0000    | GPIO Write (turn off T bias)
C0 10 0000 000A 0001 00 | VGA gain
C0 0F 0000 0007 0001 00 | Mixer gain
C0 12 0000 0000 0001 00 | Mixer AGC
C0 0E 0000 000A 0001 00 | LNA gain
C0 11 0000 0000 0001 00 | LNA AGC
40 0D 0000 0000 0004 01 | set center freq
40 01 0001 0000 0000    | receiver mode
It will take me some time to digest this.
Spitfire8520
I might be completely clueless! =)
Colorado
I noticed a minor corner case bug in regards to the UI when messing with multiple VCOs with an RTL dongle. If you repeatedly switch between 1 VCO and multiple VCOs, some of scopes persist when you switch back to the 1 VCO setting.
I also have an observation in regards to the RTL dongle and multiple VCOs. I am unsure if this would be a bug or not, but multiple VCOs appear to have weird affect on the gain settings. Whenever I use a single VCO or the first VCO with the other VCOs parked on the zero frequency, my gain settings appear to work fine and does not need to be adjusted. As soon as I set a frequency for the any other VCO, the gain setting appears to suddenly drop off and I need to bump up my gain settings or turn on one of the AGC settings to correct this. Switching the other VCOs to back to the zero frequency does not restore it, but stopping and restarting the dongle with the other VCOs set to zero will return the gain to normal for the first VCO. As a note, all the frequencies involved are less than 0.5 MHz apart.
Amraks
Hey thanks
that patch you done for the super group is working good.
I assuming my system has a radio to close super group after the dispatcher closes the group.
I just locked this radio out and it don't bother me now,.
only hear them talking on the super group channels, which I have counted 15 super group channels on my system.
Site Disable/Enable following button would be good, so you can still watch the site but not hear the site.
Eventually also a prioritization for sites would be a nice feature eventually.
So who works on Trunking Recorder, If so are they working on having multipliable voice channels?
SDRsharptrunking.log does the remote.dll output 2 voice recievers?
Or does remote.dll need to updated to output this?
eaf1956
Evansville, IN
I added a new receiver and for the life of me I can not change the stopped to Run, I have had no problems with all the other settings but can not get the program to change the receiver from stopped to run. Can some one point out what I am doing wrong, thanks for any help.
Steve
Did you remember to select the receiver before hitting the Start button? This came to me as I just tried mine and it wouldn't start until the receiver was selected.
Amraks
I have a solution for Trunking Recorder you can run multipliable instances of the program.
But the remote.dll is just recording from voice and not my second vco.
Will there be a solution to this?
Saint
Fort Erie Ontario Canada
Will not start
Thanks for the reply, I have tried everything to get the receiver to start and nothing, I even re-installed the program and still nothing. I went back to the older update and it works OK.
Steve
Mattsenft
Harrisburg, PA
Rick,
I updated to 1.0.31.18 today and noticed after a couple hours that a bunch of Radio IDs had populated into the group page. No I-calls take place on the system that I'm watching, and the only other activity other than group calls is normal system registration and affiliation messages. Is this possibly a bug?
Thanks for your continued development work on this project.
Matt
Hi Steve;
Please provide more detail. What receiver? How is it configured?
Thanks Spitfire!
The program is more efficient at processing a single VCO than it is at processing two or more. With two or more VCOs - each VCO signal must be frequency translated down to zero. The eight bit samples from the Realtek have some inherent quantization error that is slightly magnified by this translation process.
Yes, you've discovered the means to compensate for this.
