Hey everybody i got some questions i want to ask you so to understand certain things a bit better.
I hear that provoice is not really used anymore and getting the upgrade would be pointless, what is provoice exactly? the way i understand it is it's like FM or analog, What is the label for provoice here on the RRDB?
I did just purchase the DMR upgrade and i have the NXDN upgrade as well, with the DMR upgrade do you have to do any other programming or does getting the upgrade work instantly with no other programming required?
Ok is there a way to stop the scanner from doing that cut out when u press hold on a channel, what i mean is when i'm just scanning around for new things and it stops on some traffic and i press hold it first cuts out the traffic before the hold goes into effect can that be changed? i know it's petty but i'm genuinely curious.
I know alot has been said on the filters and how you really just have to test and try in a trial and error manner, i have done alot of reading on the filters and from what i understand the best for analog signals is off meaning use no filter for analog what do you all think about that? by the way i'm using wide invert for my digital channels and i think that works the best for digital and off for analog.
Now i have some channels that are on the same freqs like for instance i pick up wise 151.9550 and i pick up search and rescue with the same freqs and i have several more channels that are just like this , what do i do in these situations how do i know which is the right place for the freqs? another example is 161.8000 i pick up oakwood on STARS and i get Maritime on 161.8000 but the maritime is analog and the oakwood is P25 digital it's really confusing.
I have a DMR channel that when i pull it up on dsdplus fastlane i have a strong signal and in the event window it shows "DMR BS DCC.6 RAS" and the freqs is 154.5437 I'll attach a picture showing it. i'm not hearing any traffic on it and when i punch it in on the sds100 i just hear a BReeeeee sound for a few seconds then it stops then starts again but it doesn't show anything like on the sds100 screen like slot 1 or slot 2 it doesn't show nothing like that and i have another freqs which is 460.3625 and in dsdplus it shows DMR (MOT) BS DCC:1 i try going to that freqs on the sds100 but i get the same thing, i'll attach a pic of it as well.
One more thing what does TIIIStd [Auto] Site:L1-5.6 DCC:0 mean i have gotten these from time to time but what does TIIIStd mean?
Thanks everyone have a great day.
