- Joined
- Jan 5, 2003
- Messages
- 13,667
- Reaction score
- 9,146
- Location
- Retired 40 Year Firefighter NW Tenn
I do not think you can mix reg and sub you need to keep the pairs together
FW 1.07.02 is that for the 200 or 100?I have reverted my firmware to 1.07.02 sub 1.02.00 and I am getting much better reception than the newest firmware. Does anyone know where I can find the original load firmware, these are the earliest I could find on the google drive. My short comms are much better and distant dmr is picking up better all around it seems.
Exactly what benefit is there for remaining on 1.10, as opposed to 1.07? (Besides the "hum issue", which, in a vehicle, I wouldn't notice anyway)
I'm sorry to hear this, don't give up hope there might be an answer you can fix.I tried reverting back to 1.07.02/1.02.00 and had worse performance so I updated back to the 1.10.00/1.02.00 firmware. Since updating back I have been experiencing erratic behavior on my SDS100. My local P25P2 system is missing transmissions and showing a poor RSSI compared to before I tried the experiment. The scanner shows 1.10.00/1.02.00 as the installed firmware, but it is not behaving as such. What's stranger is that I let the scanner sit overnight, and upon initial start up it was performing like normal until I entered the menu, then the erratic behavior started again.
To fix, I have tried reverting back and forth through multiple firmwares with no success. I also tried formatting a new SD card and using that, and the erratic behavior is continuing. I thought a filter setting changed, but I am showing the same filter (W-INV) as was successful before the experiment. It seams like a hardware issue, though I don't know it this is possible just by switching firmwares. Could the sub have failed during one of the firmware changes?
Has anyone experienced anything like this, or have any suggestions? Thank you.
What do you mean by "three finger reset"?
