Would it be possible to have a selectable "skip enc" enable/disable? I have a DMR system where the dispatcher are always in the clear but some mobiles are enc and the scanner then of course immediatly leaves the system. It would also help to traffic analyze encoded systems during normal scan.
/Ubbe
So... Finally found a NXDN4800 system to monitor. I do not know if its correctly in the DB, but looking into the backend it appears it is:
https://www.radioreference.com/apps/db/?sid=7531
The 536 does NOT see this system, with the most recent updates. Does not scan it, does not show up for analyze or discovery functions.
It does see a site via CC reporting NX4 and RAN 1, but otherwise the system is not seen by the 536.
Expand please
So basically it’s still fubar on the x36’s to make it work the same way as everything else does. I was expecting that the system would show up and be scanned just as any other, and the system does not appear on any menu in the scanner.
The scanner database does not support NXDN yet that part is still being worked on if I understand your post. This is still all being worked on along with Sentinel to support NXDN. This is also why you got NXDN for $30 and not $60. So had you rather waited and not had NXDN? I am glad I got NXDN for $30 and learned how to program my scanner by hand.
The initial point I am making, a system in the database should show up reguardless of what the sites say, in th scanner.
