What did you use to extract the files from the archive?I had no problems when I transfer exe files from other versions when I move this over I get this the bottom says 0 bytes. Every file in the new update says that when I move all them over.
Sent from my SM-N9005 using Tapatalk
Has anyone used the new survey tools? If so, can you describe how they work, and maybe post a screenshot?
Edit FMP24.SurveyList to define centers of 2.4 MHz spectrum chunks.
Typically, centers are multiples of 1 MHz and spaced 2 MHz apart, for example: 770, 772, 774.
Chunks do not have to be contiguous. Example: 451, 453, 455, 461, 463, 465.
Set an appropriate gain level before starting a survey.
Press 'Y' to start spectrum survey.
FMP24 will continuously sample the spectrum chunks defined in FMP24.SurveyList.
For fastest operation, FFT size should be set to 16 in FMP24.cfg before starting FMP24.
Spectrum data is written to .survey files.
Use Survey.exe to view spectrum history.
Press Esc to stop a spectrum survey.
FMP24 Spectrum Survey Viewer
This program continuously reads the .survey files created by FMP24 during a spectrum survey.
Two windows are displayed. The first shows the peak and average levels for a 2.4 MHz chunk
of spectrum. The second shows a frequency vs time 3D display of the same 2.4 MHz chunk.
Edit Survey.cfg to set the height of the 3D display.
Edit Survey.cfg to set .CSV frequency data file names.
Edit Survey.cfg to set monitoring location and frequency data search distance.
Pressing '?' lists all active keys in the console window.
Use the left and right arrows to move to spectrum chunks.
Press [ or ] to select an appropriate step size.
Mouse over the first window to display license data.
Press PageUp/PageDown to move the mouse in fine increments over the first window;
this makes it easier to place the red mouse line on carrier centers to trigger the
license information display.
As the mouse line is moved across the first window, the corresponding spectrum
in the 3D display is highlighted. Press 'I' to isolate the highlighted spectrum
if it is hidden behind stronger signals.
To delete old survey data, delete all .survey files.
WinRAR
I never had a problem before til this one.
Did it prompt you for a password?
I used winrar and was prompted for password. All went well.
Is your DSDPlus folder in an unusual location?In winrar it shows file size but when I unzip it and shows zero file size did that happen to you?
I renamed from .zap to .7z since it's a 7-Zip file. But I doubt that's your problem.What I did was
Download the zap file
rename zap to zip
open in winrar
put in password
extract to the normal folder I use dsdplus
and all files show 0 for file size when transfer to folder (in winrar shows size files)
turn off you anti-virus then perform the action. sounds like a security issue to me.
I decided to download 7zip and that seem to work. I don't know why winrar was being a pain. I got the stuff loaded and now have to wait til tomorrow for some test since cap+ system is slow now.
