It looks like DSDPlus does not track if it fails to send the OTA alias data to the alias server and will not retry sending the OTA alias data. Reacquisition does not work to fix this because the raw OTA alias data has not changed.I see messages saying alias acquired, but not seeing the 2nd message about it going to the server and AliasStats.txt isn't updating.
So, can I assume here that there are some radios without aliases, or that are not set to do OTA? While I know the VIPER primary radios do not decode, I'm seeing a lot of county radios repeatedly that the RID alias is never caught in DSD+.
I have this issue often. Some radios are just for sitting on a desk and listening but never communication which sucks because then it's not updatedYes, you can assume that, OR it simply could be that they never transmitted. If they just registered/affiliated, you'll never get OTAAliases from them. They must transmit.
On both systems I monitor I have plenty of RIDs that register/affiliate every day but never key up. So I don't get their OTAAliases.
Yikes. If it helps you can use notepad++ and ctrl f. Search for quote space space(" ) and it will go to only the lines with an alias. If you know regex you could use Linux and remove items per line without deleting the whole lineIn my case they are transmitting, but alias is not being caught. This said I will add the overwhelming (3600) number of them have been caught
You can look at the console log to see if any alias data is being transmitted during those calls.In my case they are transmitting, but alias is not being caught. This said I will add the overwhelming (3600) number of them have been caught
It is not, from what I saw.You can look at the console log to see if any alias data is being transmitted during those calls.
My statewide system, VIPER, does decode, however it seems that few users are using this feature and decodes for those that do are hit and miss.
I have a good signal on a tower less than 2 miles away from me, I am only seeing decodes from some SHP units and a few others every now and then. Not sure why some decode and others don't, maybe it is just how DSD+ grabs/locks on to the signal.
I wish there was a way to set the re-acquisition rate to NEVER. I only want to acquire each OTA alias once and stop there.
Well, I don't think it's "odd". I know the default is 30 days. But I doubt aliases would somehow change that often.
