Sticky Thread For MilAir V (2010)
Guys,
1900 EST--HF ALE indicates that KC-10 # 87-0121 is either up and active or about to become active.
1650z was logged down in Florida today Ron showing as ETHYL 89.
Logged him here southbound a couple days ago as HOIST 90.
Maryland
coronet
Coronet update
Good evening everyone,
The final 354FS A-10s that were returning cancelled today, and are now re-filed for Sunday.
The 79FS is returning from Moron to Shaw AFB tomorrow as TREND 31-36
and TREND 41-46. Supporting tankers are BLUE 81 and BLUE 91 flight.
The 77FS is departing from Shaw AFB to Moron tonight, but their flightplan is protected ....
René.
bmlure
New Franklin, PA
Jan 22
(HF)
1347 utc: 11175.0 usb-Reach 369
1533 utc: 11175.0 usb-Check 11
1535 utc: 11175.0 usb-S4JG
1640 utc: 8992.0 usb-Car-Coat. Switched from 8992.0-15010.0-8058.0 usbs
(UHF)
1121 hr; 237.2-Crab 57
1507 hr: 378.1-Forge 46?
1552 hr: 378.1-Reach 3116
1815 hr: 349.4-Reach 9010
349.4-Reach 4138
1920 hr: 349.4-Reach 535
freqhopping
Anyone else around and awake also picking up a possible orderwire on 362.25. It's getting stronger too. Nothing on the box I can tie it to.
AF1 departure to the east? That would explain nothing on the box.
2244- BLUE93 at FL410. Still have the possible orderwire signal, figured I would've lost it by now.??
2247- Now reporting to BRICKYARD that their boom got stuck at 20degrees. 319.4
REACH-458T trying to call BRICKYARD too, still too far out apparently. BLUE93 said they would relay but 458T said they'll just wait until closer.
2257- I guess that E-6 snuck out low and to the east. 362.25 dead now but 286.1 is pegged.
2322- ???-104 on 266.8 "On the 175 for 75". Norfolk App rather than Bollen Range in this instance.
2250 local Had same also but now WBFM sw to 286.100,must be a E-6 up.
female background coms mention Nantuckett.
2254 E-6B 164410 just showed up at 29k.
2258 E-6 164410 shows again hdg 083 headed East across central Pa prob from Tinker.
BLUE 93 KC-10 #83-0081 coming in McGuire was at 41k now down to 35k.
Was logged out in Edmonton Alberta the other day.Mentions 5 writeups inbound CP.
2325 local here comes Ron's ETHYL 89 KC-10 #87-0121 prob for McGuire.
2328 ETHYL 89 diverting McGuire alpha 2 CP 319.400
2330 That E-6B has one strong WBFM on 286.100,went offshore NYC area and still burning here.
mdmonitor
Heads Up New England
Ed,
John,
Just posted on Milcom:
Hi All,
The Maple F-16's that have spent the last 2 weeks here in Tucson at Davis-Monthan AFB for Snowbird Ops are on their way back to VT. Maple 11 a flight of 4 just was handed off to ABQ Ctr.
Bruce
Monitoring in the Cold Desert Southwest
coronet
79FS returning to Shaw AFB
Good evening,
Only one cell made it out of Moron this morning, and they are now working Boston center on 133.450.
1730z BLUE 81 flight, a flight of seven, checking in with Boston center on 124.525.
René.
Good evening,
René.
Good afternoon here René.
I see a BLUE 81 KC-10 #86-0028 on the net and a couple TEAM McGuire
KC-10's as well.TEAM 61 #86-0027 and TEAM 62 #85-0032 up that way as well.
1759z TREND 31 checking in ZDC 257.700
1810z On 370.925 block 21-230 mentions direct Charleston.
Mark,
Tin,
1335 EST C-5B 85-0005 is sounding in HF ALE--belongs to 9th AS at Dover
That C-5B tail disappeared here back in late April 2009 and hasn't been logged
anywhere since.
Maybe getting a overhaul down in Georgia?
A ROGUE 46 came into Dover early this afternoon with a bunch of writeups so maybe that was him.
coronet
Thanks for the update Mark.
The final 354FS A-10s should be arriving at Martin State airport Sunday January 24
as TREND 21-26 with tankers BLUE 71/72/73. Their ETA is 1845z.
And the first cell should be departing back to Davis-Monthan AFB at 1500z.
The final 31FW F-16s should be arriving at Eglin from Lajes tomorrow aswell as TABOR 71-72.
René.
Unusual stop for staging Tankers but tonight
GOLD 12 KC-135 #57-1488 6thAMW/171ARW arriving Dover 2110 local,req follow me truck.
GOLD 02 KC-135 #60-0344 319th AW Grand Forks arriving Dover 2125 local.
A couple more GOLD's staged at Pease tonight as well.
GOLD 01 and GOLD 21.
jsoergel
Cincinnati/Dayton, OH
Did anyone happen to log a Brasilian military flight today? I picked up an aircraft calling Patterson Metro with a very distinct accent - it sure sounded Brasilian - this evening; it was weak, but I think the last two numbers were "82." Logs to follow.
jsoergel
Patterson 1/22:
SAM 50050 (C-20C, 85-0050) - support of POTUS trip to CLE
MASH 51 (KC-135R, unid) - to KSUU
HX 760 (2x AH-1Z, 166760, 166772?) - VFR departure SW...I snapped a quick pic (from a distance), if anyone wants to see it just send me a PM
CODY 02 (unid) - called Metro for weather at KVOK
CLAW 65 (C-17A, unid) - called Metro for weather at KBLV and KFFO, 30 mi E KFFO, FL320
JOSA 208 (C-21A, unid) - DV pickup, requesting 3000 lbs fuel and power cart
SAM 50050 (C-20C, 85-0050) - to KADW
JOSA 208 (C-21A, unid) - to KBED
ALOUETTE 55 (CF-188, unid) - arrival
1/23:
PAT 620 or 628 (unid) - called Dispatch...departure message?
RHINO 27 (C-5A, unid) - training, A2 for nose gear out of balance, parking A2
REACH 9003 (C-5A, 69-0003) - departure...overseas flight, maybe to ETAR?
MUSIC 81 (C-130H, 89-1181) - interplane coordination? (heard "MUSIC 81 push COM-3" and "MUSIC 81 push ops freq")
LEDGER 53 (E-4B?) - approach before landing
RHINO 90 (C-5A, 70-0461) - returning from mission
UNKNOWN - called Metro, 50 mi SE ??
Mateo
The Dee Sea
Likely Embraer 135 2582 (designated as a VC-99). The Brazilian Air Force Legacies get around in the US, so it's a decent bet. Hex should be E40141 if someone in your area has a Magicbox.
coronet
Upcoming deployment
A couple more GOLD's staged at Pease tonight as well. GOLD 01 and GOLD 21.
Hi Mark and all,
Probably to do with this KWRI NOTAM:
M0022/10 - RUNWAY 06/24 CLOSED TO ALL AIRCRAFT OPERATIONS DUE TO
CONSTRUCTION. 19 JAN 12:00 2010 UNTIL 15 APR 16:00 2010. CREATED: 16 JAN 12:07 2010
All those GOLDs should be supporting the 77FS deployment from Shaw AFB tonight.
Hope this helps,
René.
