Sticky Thread For MilAir V (2010)
Hi Mark and all,
Probably to do with this KWRI NOTAM:
M0022/10 - RUNWAY 06/24 CLOSED TO ALL AIRCRAFT OPERATIONS DUE TO
CONSTRUCTION. 19 JAN 12:00 2010 UNTIL 15 APR 16:00 2010. CREATED: 16 JAN 12:07 2010
All those GOLDs should be supporting the 77FS deployment from Shaw AFB tonight.
Hope this helps,
René.
Thanks René as that closing going to make things difficult at McGuire.
That leaves McGuire with only the shorter 18/36 runway in op.
Not sure if a fully loaded KC-10 or KC-135 can take off on that shorter
7k runway vs the 10k closed runway 6/24.
Dover has newly refurbished 12k runway 14/32.
Tech792
Central NJ
1019 local- TEAM 71, 72, 73 with GK on 135.225. Request FL230 in W105. Interplane on 139.875
On the way back to McGuire, will be stopping at ACY for some approach work.
jetcrafter
Southern Maine
Did anyone happen to log a Brasilian military flight today? I picked up an aircraft calling Patterson Metro with a very distinct accent - it sure sounded Brasilian - this evening; it was weak, but I think the last two numbers were "82." Logs to follow.
Hi Jared,
Yes, I logged him yesterday in New England. Here's what I had:
0257z 135.700 BRAZILIAN AIR FORCE 2582 check in w/ZBW, FL380.
0307z 135.700 BRAZILIAN AIR FORCE 2582 descending from FL380 for 210.
Here's info from a person who had an SBS box:
VC-99 FAB2582 is the serial
Hope this helps.
Tin,
Mark,
Travis,
got this off another list:
For those interested there is a new MC-12W 09-0642 for your notes.
Michael Sharritt Athens,Alabama
Yeah Ron there is a lot of them coming.
Just go into FAA database and search serial #s FL-320 and up
and you will see lots of deregistered BE 300's 12/08/2009.
Some for export but most for future MC-12W's.
The dereg serial FL-*** ends up in the final USAF tail like
FL-642 for the above example 09-0642.
coronet
A-10s returning
Good afternoon,
1840z BLUE 71, a flight of seven checking in with New York center on 125.925.
1845z BLUE 71 handed over to Boston center on 133.450, likes to depart the formation and the A-10s TREND 21-26 will continue in the block 200-240.
1847z TREND 21 flight checking in on 133.450 aswell.
1850z BLUE 71 is cleared to Dover AFB.
1852z TREND 21 is cleared via ACK, Rifle, RBV to destination Martin State airport.
1905z REACH 515 flight checking in with Boston center on 133.450 aswell. Could be dragging the "AV" F-16s to Eglin.
1912z CLEAN 51 checking in with Boston center on 133.450, cleared to Dover AFB.
1914z REACH 515 has two F-16s with him, TABOR 71 and 72.
1920z TREND 21 flight handed over to Boston center on 124.525.
René.
Good afternoon,
René.
1943z heard some Coms on Raven Ops 347.200
1952z BLUE 71 landing Dover tower 126.350,too low for me to get box id.
1959z CLEAN 51 checks in with ZDC Sea Isle 127.700 "direct Sea Isle"
2001z Finally getting TREND 21 A/A 281.350 mentions #5 and #6.Thats a new A/A for me.
2005z REACH 515 getting metro wx on 271.600 for KPSM,KVPS and KPAM.
Have a KC-10 #84-0192 showing at 25k.pirep 271.600 says he is at Snow Hill vortac and
a DC-10.
CLEAN 51 was inbound Dover in there 132.450.
2018z TREND 21 on Martin Tower 121.300 "flight of 3" at overhead FL2k landing.
2020z TREND 24 flight of 3 with Martin Tower.
2022 TREND 24 rolling out to stops.. ...Thanks René for heads up!
freqhopping
Got unknown (supposed C-32) AE0446 with ADS-B. ELKIN-44 132.95>133.9
Heading in the direction of Pax, probably going to Dover
1724- Descending to FL110 from 190.
Now found that is it 99-6143
1852- ASCOT-5725 ZH870 C-130 inbound for Dulles. 120.45>134.2
adrian65
Marthas Vineyard, Ma
1955 local
Just had this go past me at FL350 heading to the NE, now with L9308 in the c/s block. Never did
hear it on the radio.
freqhopping
ASCOT-5725 ZH870 C-130 is departing Dulles. They gave a PIREP at the request of PCT. They were asked about any icing as well.
As far as I can tell ZD950 L-1011 still hasn't departed Dulles. That one came in really early Saturday at 0220 local as RRR9389.
2206- DHS Agusta Spa AB139 N140HS is inbound from some place distant. Picked up at over 6000ft. 120.45
2209- It will be landing at Manassas. Contacted Volo Aviation about fuel. 128.9
CitationJet
Northern Virginia
Andrews NOTAM
This is ancient but I just noticed it up on the site...posting it just in case.
L0122/09 - COMMAND POST VHF 141.55 OTS CONTACT GRIFFIN AT UHF 378.1. 22 DEC 11:21 2009 UNTIL
15 MAR 23:59 2010. CREATED: 22 DEC 11:24 2009
CitationJet
Northern Virginia
01.15-20.2010
Hi,
A bit old but trying to catch up here little by little.
IAD = Washington/Dulles IAP
JBANAFW = Joint Base Andrews Naval Air Facility Washington
KNYG = MCAF Quantico
NHK = NAS Patuxent River
NXX = NAS JRB Willow Grove
PT = Potomac TRACON
ZDC = Washington Center ARTCC
01.15.2010
1915Z 118.675 PT A/D - VENUS 50 (C-20C 85-0050 99th AS) - QSY PT APP
119.850 > PT APP 119.300.
1919Z 143.150 121st FS DC ANG IP - BULLY 1 (F-16C/D 121st FS DC ANG) -
A/A comms.
1926Z 118.400 Andrews AFB TWR - SCORE 52 (C-130T VX-20) - ILS rwy 1L apps.
1933Z 119.850 PT APP - COAST GUARD 101 - i/b DCA.
1933Z 128.350 PT APP - MANGO 55 (C-40A 01-0015 65th AS) - i/b rwy 1L Andrews.
1944Z 118.400 Andrews AFB TWR - PACER 78 (C-21A 457th AS) - lands rwy 1L.
1947Z 118.400 Andrews AFB TWR - MANGO 55 (C-40A 01-0015 65th AS) -
landing rwy 1L fs on rwy then accelerate to test brakes requested.
01.19.2020
1141Z 133.900 ZDC-Calvert - NAVY 7A 501 (UC-12B 161501 NHK) -
1.5-5-15K dir GARED QSY ZDC-Casino 127.700.
1924Z 133.900 ZDC-Calvert - VENUS 41 (C-37A 97-0401 99th AS) - 10K.
1925Z 128.350 PT APP - REACH 0349 (KC-135R 60-0349 77th ARS AFRC) -
12K i/b Andrews rwy 1L.
1927Z 121.900 Davison AAF GRND - GUARD 72054 (UH-72A 07-2054 121st
Med. Co. DC ArNG) - North side for dep. for hover work.
1928Z 378.100 GRIFFIN CP Andrews - REACH 0349 (KC-135R 60-0349 77th
ARS AFRC) - arr. msg. 20 mins. out.
1934Z 118.400 Andrews AFB TWR - NAVY 101 (C37A/B VR-1) - QSY PT DEP
118.950 2.3-3-5-6-15-17K QSY PT A/D 123.825 dir MCRAY join J518 QSY
ZDC-Hagerstown 134.150 req. FL430.
1935Z 123.825 PT A/D - SAM 6473 - join J158.
1940Z 119.850 PT APP - NAVY 7C 107 (UC-12M NAS Oceana NFD) - to 6K
vis. rwy 32 at Davison.
1950Z 118.950 PT APP - PAT 307 - off Davison 1.2-2-5K.
01.20.2010
1107Z 133.550 ZDC-Linden - CANFORCE 3918 (CC-130) - FL210 down one
motor no issues at this time RTB and ETA CYTR 1220Z QSY ZDC-Hagerstown
134.150 "just wondering if that escort out there is for us?" QSY
ZNY-Middletown 132.200 dir CYTR "precautionary shutdown".
1923Z 119.300 PT APP - VENUS 40 (C-37A 97-0400 99th AS) - QSY JBANAFW
TWR 118.400 outside PREZZ for the option rwy 1L. Deps later w/PT DEP
125.650 dir PALEO QSY PT APP 124.550.
1925Z 128.350 PT APP - BOXER 82 (C-38A/C-40C 201st AS DC ANG) - ILS rwy 1L.
1925Z 128.350 PT APP - VENUS 92 (C-32A 98-0002 1st AS) - ILS rwy 1L.
1935Z 123.825 PT A/D - REACH 468 and ????? 47 up on freq briefly.
1955Z 133.900 ZDC-Calvert - OTIS 10 (KC-130J VMGR-252 MCAS Cherry
Point) - FL190.
2039Z 119.300 PT APP - NAVY 7C 895 () or 7N 795 () - 4K-3K ILS rwy 1L Andrews.
2042Z 260.900 PT HUNTRESS - SAM 6493 wkg PANTHER (JDOC Bolling AFB) -
for Sparkle test. Also up w/PT APP 119.300 4K inbound Andrews.
2112Z 133.900 ZDC-Calvert - ARMY 23382 (C-12 92-3382) - FL230 dir
COLIN HPW VORTAC.
2116Z 133.900 ZDC-Calvert - OTIS 10 (KC-130J VMGR-252 MCAS Cherry
Point) - FL180 QSY ZDC-Dominion 118.750.
2129Z 119.300 PT APP - VENUS 40 (C-37A 97-0400 99th AS) - TACAN-A 1L.
2131Z 119.850 PT APP - PAT 044 (C-12) - 8K req. vis Andrews 1L.
CitationJet
Northern Virginia
01.21.2010
01.21.2010
1139Z 133.900 ZDC-Calvert - NAVY 7A 501 (UC-12B 161501 NHK) - 1.2-3-15K QSY ZDC-Woodstown 132.050.
1905Z 133.900 ZDC-Calvert - SCORE 52 (C-130T C-130T VX-20) - QSY NHK APP 120.050.
1906Z 119.300 PT APP - VENUS 44 (C-37A 99-0404 99th AS) - QSY ADW TWR 118.400 rwy 1L opt to rdr.
1913Z 128.350 PT APP - ARMY 10301 (UC-35C 01-0301) - 12K dir IRONS.
1913Z 119.300 PT APP - SAM 50049 (C-20C 85-0049 99th AS) - QSY ADW TWR 118.400 8 nms. ILS rwy 1L.
1915Z 119.850 PT APP - TITUS 24 (C-12C 89th AW) - RNAV rwy 1L 10K-6K.
1920Z 125.650 PT DEP - LOBO 047 (C-9B VMR-1) - 5K-17K dir DAILY.
1930Z 133.550 ZDC-Linden - EVAC 46703 (C-130H 94-6703 169th AS IL ANG) - QSY PT APP 120.450 9K.
1933Z 378.100 GRIFFIN CP Andrews - EVAC 46703 (C-130H 94-6703 169th AS IL ANG) - clg here no joy.
jsoergel
Cincinnati/Dayton, OH
I was surprised when I checked my recordings from this morning to hear a NAOC exercise taking place:
"Wright-Patterson AFB is under alert conditions all aircraft remain clear of Class D airspace until further notice."
MILL 64 (E-4B, unid) checked in with ground advising that they were starting engines. Several minutes later they called back for clearance and taxi:
MILL 64 cleared to KFFO as filed, except change route to read SGH > APE 260r > APE > AIR > then as filed. On departure fly runway heading and maintain 3000, expect FL290 10 minutes after departure. Departure frequency 118.0, squawk 4013.
Ground advises them to use caution during taxi on right turn, security forces at 4-5 o'clock. After taxi and positioning on 23R, the tower cleared them for takeoff; 64 cancelled takeoff and told the tower they could terminate the alert, then taxied back to park.
I've got a recording if anyone would like to hear it.
coronet
77FS deployment
The Shaw Vipers should be departing tonight between 0200 AM and 0400 AM local time .....
The 77FS deployment was delayed, now departing tonight at 0300AM:
Storm postpones Shaw pilots' departure 25-01-2010
A violent storm that ripped through South Carolina postponed the deployment
of pilots and F-16 fighter gets from the 77th Fighter Squadron "Gamblers"
from early Monday to early Tuesday, Shaw Air Force Base announced Monday.
The pilots are now scheduled to deploy at 3 a.m. Tuesday from the Shaw
flight line, according to a news release.
These pilots will be the last of more than 300 airmen from the 20th Fighter
Wing to leave for Iraq in support of a four-month air expeditionary force
deployment.
According to Lt. Col. Lance Kildron, 77th Fighter Squadron commander, the
pilots will fly close air support missions in Iraq to support troops on the
ground.
So another try in a few hours ...... happy listening !!
René.
bmlure
New Franklin, PA
Jan 25
(VHF UHF)
0751 hr: 311.0-Steel 62
1535 hr: 141.55-Reach 3114
1806 hr: 349.4(Brick Yard)-Reach 0461
1952 hr: 311.0-Echo 55
