DSDPlus DSD+ 2.289
mrc333777
Barberton, Ohio
Change Log
DSD+ 2.289
Added support for P25 trunking systems that broadcast limited site and network information.
Added sync pattern detection for ProVoice simplex / inbound transmissions.
Updated DMR talker alias reporting.
Added support for more DMR position reporting / AVL message formats.
Modified call alerting options.
Fixed some srt file issues.
Added metadata headers to per-call wav and mp3 files.
Reconrider
Inside the Galaxy
Radio Galaxy
a417
They've done that a couple of times before, usually for a hasty bugfix. Lets see if a new revision pops up in the next couple of days.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
no the old link provided "www.dsdplus.com/dsdplusuploads/FastLane ...." is not working anymore.
I will wait a couple of days ....
You can't get anything from https://www.dsdplus.com/dsdplusuploads/Fastlane just by browsing that URL (and that IS intentional). You must have the absolute full link to download. Fire up your DSDPlus Fast Lane, and when you fire it up it will let you know that there is an update available and will give you an option to download/save the update in your DSDPlus folder. Everyone should be keeping up to date. You don't want to get behind.
There are only links to DSDPlus2p289 and DSDPlus2p275 on the server. If you need anything older, you have to email dsdplusfastlane@gmail.com
Reconrider
Inside the Galaxy
Radio Galaxy
https://www.dsdplus.com/dsdplusuploads/FastLane/XXXXXXXXXXXXXXXXXX_DSDPlus2p289.zip that's the link format you need to use. the 'XXXXXXXXXXXXXXXXXXXXX' is the random characters that makes it personalized to you and only you. You can find that "code" in your email from dsd. If you can't find that email, email dsdplusfastlane at gmail.com like mtindor said and dsd will reply when he's able to for your link.
martufello
pro92b
Mutated Member
I use DSD+ with the microphone input on a laptop, fed from a discriminator tap. This works fine in version 2.275 for DMR control channel monitoring. In version 2.289 the microphone input is greyed out and cannot be selected so I have no way to get the input I need. Is there some setting I can change in DSD+ to activate the microphone input or is this a result of the update?
radioopperator
FYI 2289 seems to be BUGGY!!!! when you go to do aliases!!!!! IT CRASHES.....1612197184050.png1612197184050.png
slicerwizard
Toronto, Ontario
Sounds like you need to change the monitoring mode in the control menu.
mtindor
FMP24 PRO USER
like @slicerwizard said -- Control --> Passive Digital Monitor. Once you do that, switch back to Input and select your input.
mtindor
FMP24 PRO USER
FYI 2289 seems to be BUGGY!!!! when you go to do aliases!!!!! IT CRASHES.....View attachment 98079View attachment 98079
You should attach large screenshots instead of imbedding them. I'm sure there are plenty with better eyes than me, but my eyes find it blurry and diffcult to read. If you want the author of DSDPlus to pay attention you will want to copy/paste the text from the crash window and send the screenshot of just the crash window (you can focus on it and alt-printscreen) - send it to dsdplusfastlane@gmail.com .
radioopperator
Didn't mean for it to do a double take I clicked it once. But I did find the email and forwarded it off.
Seems new version has issues with recordings and any changes to aliasing.
hrh17
I've noticed when using discriminator tap through the microphone input with Passive digital monitor active dsdplus will decode the audio but will not save out the audio to a wav file. Soon as I switch the control back to CC Monitor it will decode and save the audio to file. Anyone else encountered this?
