DSDPlus DSD+ 2.289
a417
My bad, forgot I was going thru OneDrive. Just went up and did it from pc with 7zip and winrar
Thanks @mtindor
Changing your .zip file association within windows explorer can help you avoid this in the future.
Windows Explorer .zip integration blows, but 7Zip does a pretty good job at being better than it in every way.
dave3825
Suffolk County NY
Changing it to what? I just looked at file associations in this win 10 machine and I don't even see a .zip
I usually run all sdr on pc upstairs but with my son doing remote I hijacked the pc that I set of for my wife to work from home. I never had a problem upstairs and did not even realize I was downstairs. I was still on first coffee.
a417
right click any .zip file, select properties. (note Open with:) change from File Explorer to 7-Zip (console), notice how file association changes in the Open with.
u2brent
OAMPT
KRWDPAXKRS1
using the new dsd exe created a issue shown below
The directions say something like this...
Code:
Change Log
DSD+ 2.289
    Added support for P25 trunking systems that broadcast limited site and network information.
    Added sync pattern detection for ProVoice simplex / inbound transmissions.
    Updated DMR talker alias reporting.
    Added support for more DMR position reporting / AVL message formats.
    Modified call alerting options.
    Fixed some srt file issues.
    Added metadata headers to per-call wav and mp3 files.
DSD+ 2.275
    Fixed critical date handling bug.
DSD+ 2.268
    Fixed P25 channel 0-0 handling.
    Significantly improved Fusion decoding.
    Added dPMR link control display and AMBE+2 voice synthesis.  dPMR decoding has to be enabled.
    Modified site loader window operation:
      Controlled by mouse / pointer device only; no keyboard inputs.
      Left or right click on an entry to highlight it.
      Left click highlighted entry to tune to it and close site loader window.
      Right click highlighted entry to tune to it and leave site loader window open.
    Added direct connection mode:
      Connects DSD+ to FMPA/FMPP/FMP24 without using network.
      Use -i<linkID> on DSD+ command line for direct connection.
      Use -iT<addr:port> on DSD+ command line for TCP link to remote PC.
    Added integrity check for lame_enc.dll file; correct file is in DLL bundle at dsdplus.com
    Added menu entry to download newest base files.  Provides access to up to date copies of
    all DSD+ companion programs, configuration files, batch files, data files and required DLLs.
Illinois, multiple sites
See the bottom menu item :unsure:
which version is the base file option added in. as the current release will not open due to this check. [This information would have been useful to know.]
EDIT:
what version of lame? 3.99.2.3 does not work.
2.289
2.275
2.268
2.256
too old for "download newest base files" [last functioning version]
I do not have these versions.
2.228 too old for "download newest base files"
I guess a better question is: "what version supporting the old file"?
Unable to perform update to base files
Issue: make required checks after allowing update of "base files"
BM82557
Berkeley Co WV
Why would the cc freq of 2 site neighbors be displayed but not for the 3rd site neighbor? --
WX4JCW
Stow, Ohio
one thing I have noticed if a system uses a key ID of 0 it will not display the key ID
dave3825
Suffolk County NY
Should the bandwidth change from 9.5 to 12.5 on a phase 2 system during voice calls? I do not see it doing this on phase 1 systems.
Honestly I am amazed it doesn't automatically change to the appropriate bandwidth. I usually set it to 9.5 then it changes to 12.5 to accommodate the p25 phase 1 system by me.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Yes. Phase II voice is QPSK and is 12.5 khz. CC is C4FM if it's a standalone site, or QPSK if it's a simulcast.
So assuming you are monitoring a standalone Phase II P25 site, it's behaving as it should.
Mike
